2000 Formula won't start Went to the store and when I came out the car wouldn't start. Got it towed back to the house. Removed starter, had it tested, and it works fine. Replaced Ignition relay and starter relay with fan 1 and 2 relays. Car still will not start. Lights do not dim when trying to start the car. Battery is new and fully charged. Where do I go from here? |
Does the tach move when cranking? And check engine light? I'm guessing it's turning over? Can you hear the fuel pump/test the fuel pump relay? |
tach does move. Engine will not crank. I can move the crank by hand with a socket. No check engine light. I can hear the fuel pump. |
Next step sounds like checking all the fuses, grounds on the heads, check for power to the injectors and coils. You could pull a plug and see if you have spark. Then check fuel pressure. If there is a light on see about borrowing a scan tool of some sort to run the codes. |
| All times are GMT -5. The time now is 03:34 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
