Off-Road Y-Pipe for oem manifolds pros and cons
Old 04-14-2011, 01:15 PM
cpo
cpo's Avatar
Default Off-Road Y-Pipe for oem manifolds pros and cons
I don't want to install headers until I'm ready for an engine rebuild or swap. With that said, I would like to ditch the factory Y and go with an off-road. The remainder of the exhaust piping is stock with the exception of a Dynomax Bullet (sounds great!) in place of the factory muffler.
CONS: exhaust smell, potential fines/tickets (unlikely in FL), rear O2's would need to be tuned out, louder.
PROS: cheap(er), louder, more hp, can resell it later.
Am I missing anything? Expect hp gain? Which vendor/s here sells them? Lastly, anyone in the Gainesville FL area wanting to sell theirs? I'll drive an hour or so to pick it up.
Old 04-14-2011, 01:23 PM
HoLLo's Avatar
I'm curious why you won't do headers now? Headers even on a bone stock car are a huge gain. Not to mention the great sound!!
Old 04-14-2011, 01:28 PM
cpo
cpo's Avatar
Wifie has me on a tight budget, so I'd prefer to go this route for now. Same with my cat back. I kept the factory piping, and just had a Dynomax Bullet installed all for less than a hundred bucks. Maybe a few hp less than a full cat back, but waaay cheaper.
Old 04-14-2011, 01:51 PM
JRENIGAR's Avatar
Why not just gut the cats for now and save the money if all your after is sound? BTW if you eliminate the cats your gonna have rasp. You can count on it. Its not gonna help with hp any either. Just so you know.
Old 04-14-2011, 02:07 PM
HoLLo's Avatar
Gutting the cats won't save you any money when there's people on here buying the stock cats for almost $100/pair!!!
Old 04-14-2011, 02:50 PM
cpo
cpo's Avatar
Really....
Guess I need to post a For Sale and For Trade ad.
What amount of hp gain can be expected for an off-road Y to factory manifold swap?
Old 04-14-2011, 03:18 PM
JRENIGAR's Avatar
None. Actually, might loose a lil bit of torque down low. Not worth the hassle if converters are good.
Old 04-14-2011, 03:20 PM
JRENIGAR's Avatar
I was referring to doing the cat gut project yourself versus buying a y pipe from somewhere. I just use a sawzall to cut the pipe infront of the cat and a large screwdriver to breakup the bricks then dump them out and a mig to weld the pipes bact to the front of the cats. Looks almost factory except the small weld bead at the front of the cats. Free sound but no hp I noticed. Went with lt's and havent looked back...
Old 04-14-2011, 03:32 PM
cpo
cpo's Avatar
But what about all of the flat piping that would be replaced with mandrel bent 3" stock? That alone should be worth a few hp. And no cats vs 98K mile factory cats also have to be worth a few hp. Nothing groundbreaking, but it something nonetheless.
Old 04-14-2011, 03:49 PM
JRENIGAR's Avatar
Thats kinda iffy to me. I had mods in sig and went to td's and actually was slower. I lost alot of torque down low. Went back to single 3in over the axle factory type setup and felt better. Mani's have a bottle neck at the flange that no ammount of bigger exhaust will fix after the fact. Id just do headers if anything.
Old 04-14-2011, 03:58 PM
cpo
cpo's Avatar
Interesting.....
btw, I like your mods, definitely a great path for bang-for-the-buck. All you need now is a cam upgrade and you should be pushing around 400whp, right?
The following users liked this post:
Tireman1 (08-31-2019)
Old 04-14-2011, 04:37 PM
HoLLo's Avatar
If you want to pass visual emissions if you have it.. just cut off your cats and install some of these.
Then sell your stock cats for almost $100!. Check out the WTB section
Old 04-14-2011, 05:30 PM
thegodfather899's Avatar
^^ those are sweet. do they even make an ORY that can mount to stock manifolds?
Old 04-14-2011, 07:56 PM
JRENIGAR's Avatar
Originally Posted by cpo
Interesting.....
thanks. I was gonna do a 3200 or so stall real soon then maybe a eps 222/226 cam sometime after, but Im just another broke racer tryin to go fast, so well see how it goes. 400rwhp, that would be great.
Old 04-14-2011, 07:57 PM
JRENIGAR's Avatar
yes, I wanna say its made by walker or something like that. I think it was on ebay but might have been somewhere else.
Old 04-14-2011, 08:26 PM
s346k's Avatar
with no tune the car lost 2 mph and 8 mpg by removing air/egr and swapping the stock y for an ory. not sure what a tune will do, i hope to find out soon. car was all stock except for lid and weld in flowmaster.
edit: the weirdest thing i noticed is that the 1/8 mph is down 6, but the 1/4 is only down 2...just something i noticed. the car consistently backhalves 27-28 mph now where it only went 24ish before. not sure what that's all about. it still feels just as "torquey" as it did with the factory y.
Old 04-15-2011, 05:05 PM
cpo
cpo's Avatar
So who wants to sell their used off-road Y for stock exhaust manifolds? Also, who sells these new?
Old 04-15-2011, 05:17 PM
TheSilverOne's Avatar
i would save my money
Old 04-15-2011, 05:18 PM
99 Blue Bird's Avatar
ws6 store has a **** load of them. i most likely will buy one or just have one made with a flowmaster merge. also thinking about putting in some electric cutouts aswell. i am going for a super stealth mode setup. should be makin over 390rwhp through stock manifolds easy. plus a little hidden laughing gas setup to put me in the 550rwhp range. people wont know a thing if they check out my car and neither will the police or smog guys here in **** California.
Old 04-15-2011, 05:19 PM
keep us updated
Quick Reply: Off-Road Y-Pipe for oem manifolds pros and cons
