Would dumped LTs be ok on my setup?
Old May 25, 2011 | 06:26 PM
kilgothephenom's Avatar
Talking Would dumped LTs be ok on my setup?
Hey guys, I did a lot of searching and found some, but not all of the info Im wanting. My car has the mods in my sig. Right now I have the Hooker longtubes mated to Lanes true dual X pipe system with dumped bullets before the axle.
Im starting to make pretty good power and Ive broken two tailshaft housings on the dyno so Im trying to go with a UMI TA. I know they dont work with X pipes and I dont want to go with a Y pipe. Im not saying a Y pipe would rob me of a lot of power, if any at all, I just dont like the sound.
I wanted to go with bullets right off the collectors. My questions are how do you get it to fit on the drivers side? I read people literally beat it with a hammer but I want to know exactly what to hit to avoid warping any kind of frame or bodywork. My other question is how loud will that be? With my dumped true duals, it doesnt bother me at all. I dont even consider it loud and wouldnt mind it being louder to be honest. I just dont want open header loud...that ridiculous.
Finally, would I make more/less power or stay the same? Would I need to have it retuned on the dyno?
So, any suggestions?
Old May 25, 2011 | 09:24 PM
zracer323's Avatar
You will probably make the same power bc it is basically the same setup with a little less piping. You will prob pick up a lot of cabin noise bc the exhaust will he exiting right underneath you
Old May 26, 2011 | 01:16 AM
99SSJarhead's Avatar
If you look at most pipes on TD's coming off the driver side long tube, that first bit of pipe usually has two bends in it. Hooking a bullet straight to that pipe instead of off the long tube will save you having to massage your floor.
Old May 26, 2011 | 02:26 PM
Yea ive seen people with about 18 inches of pipe, before the bullet, on the drivers side. Any way to do it without the extension? Id like to try and do it myself opposed to an exhaust shop and dont have 3" piping laying around, or a mandrel bender.
Old May 28, 2011 | 01:43 PM
Any ideas?
Old May 28, 2011 | 02:04 PM
99Bluz28's Avatar
Just make sure you have 30" (minimum for a 3" collector) from the O2 sensor to the exhaust exit, otherwise you can get a false lean reading from the O2 sensors.
Old May 28, 2011 | 04:44 PM
Ok, ive actually never heard that. How do people get away with running open headers then?
Old May 28, 2011 | 05:00 PM
67RSCamaroVette's Avatar
It won't run right with open headers. The O2's actually see outside air (oxygen rich) between exhaust pulses, making it run rich.
