243 heads stock on 2007 5.3L suburban?
was looking at a suburban for the wife this evening and noticed the 5.3L in it had 243 heads. Both sides, clear as day.. Is this correct? ..just wondering if somebody has been into the motor.
Engine apparently is an LC9 if anyone can break that down
Thanks,
TJ
Thanks,
TJ
heads
Did the intake port change at all on the heads. I have some older cathedral port motors but haven't dealt with the L92 heads. Saw the '07's have the newer style intake with the 4 bolt throttle body. Just wondering
The 241/853 LS1 head is a 67cc chamber and (I think) around a 200cc intake runner. The 243/799 casting is a 64cc and around a 210cc runner. More compression and the potential for more flow volume is why they perform better. Because the port is somewhat tweaked, they produce better results when ported as well, as opposed to a standard LS1 or 5.3 head. Valve size is the same for all 4 of these heads. I don't know much about the 5.3 heads except the chambers are likely around 62cc, they have smaller valves, and they flow like crap in stock form. I really don't think they are that great of a head when ported either (from what I've seen).
For flow: 243/799 > 241/853 > 5.3
For compression: 5.3 > 243/799 > 241/853
And the 317s are basically the same as 243/799s just with 72cc chambers (more deck thickness) for really low compression. A favorite among the boosted applications.
