98-02 Trans Am Camaro Stainless Steel AIR LID w Nitrous
What do you guys think about this lid? its cheaper than other lids but I have never seen a stainless steel lid or even heard of people with these. Its $69.00 on eBay.
"98-02 Polished Stainless Steel 90mm LS1/LS6 Nitrous Ready High Flow Lid
Auction is for one new ls1 polished stainless steel lid with dual nitrous bungs. Item fits the 98-02 LS1/LS6 Chevy Camaro and Pontiac Trans Am. Finally a great looking solution for under the hood and functional at the same time. This lid features 2 nitrous bungs on either side, resulting in the perfect setup to run your dry nitrous kit equally spraying from both sides. The bungs accept the most common nozzle size so installation is a breeze. The lid is finished off with a mirror polish finish to match your other under hood custom accessories. Also, expect a 5-10 HP and TQ increase depending on setup. The metal lid is plenty strong so don't worry about nitrous backfires shattering your plastic lids. So ditch your plastic stocker or aftermarket ill fitting plastic lids that fade and go with one that functions and lasts. If you don't run nitrous the lid comes with anodized fittings to keep both bungs closed when not in use. No couplers are included because everyone has different MAF/TB setups. Large side hole is for engines with AIR, it can easily be plugged up. Lid outlet is ~90mm, sized to accept aftermarket large MAFs, however a coupler is recommended for a good seal. If you need a smaller lid outlet, please check our store for the same lid but with a ~100mm outlet opening."
http://cgi.ebay.com/ebaymotors/98-02...Q5fAccessories
Yea i was just wondering if anyone had seen this before or used it. I'm looking for a good lid and ran into this on eBay. The price was what got my attention. But i mean it is most probably heavier and probably absorbs heat and heats up the cold air goin through right? OK so this SLP lid, is it better that the fast toyz one? I'm stuck between getting one of these two lids.
