Sensor???
Old Aug 21, 2011 | 01:13 AM
Paul57's Avatar
Default Sensor???
Does anyone know what the sensor/component is on the left side of the block, towards the rear?? I took a pic but it is too big. It is about an inch in diameter and 2 1/2" long. I would like to find a plug for it if anyone makes one. Does it just twist out??
Old Aug 21, 2011 | 11:49 AM
Paul57's Avatar
I figured out how to edit the pic. What is this and is there a plug for it??
Old Aug 22, 2011 | 10:07 PM
Paul57's Avatar
No one knows what this is or if it can be deleted/plugged easily??????
Old Aug 22, 2011 | 11:13 PM
Deviant LS1's Avatar
Block heater for cold weather?
Old Aug 23, 2011 | 08:44 AM
MM98's Avatar
Exactly! GM didn't put those on their gas engines from the factory, they were an accessory add on.. A coolant plug goes there, GM# 12561663, runs about $9 from the dealer. Just un-screw the heater element, it has a hex body around the electrical connection & replace with the # I listed.
Old Aug 23, 2011 | 08:16 PM
Paul57's Avatar
Thanks for the help, especially the part number. I was kind of thinking it was a block heater but had never seen one before.
