valve cover spacer gasket material
Old 05-27-2011, 11:11 AM
camarof41_383's Avatar
Default valve cover spacer gasket material
I have a set of UMI valve cover spacers. I would like to buy some extra gasket material for them but can't find it anywhere. Anyone know where to buy it at? Its 1/8in o-ring gasket material that you cut to length. I wish these spacers used the stock type gaskets that would be much easier.
Old 05-27-2011, 01:03 PM
DirtyDirk's Avatar
GM engine sealant part #12378521. Its a rtv sealant. Would work great with that design. Same as duramax valve cover.
Old 05-27-2011, 01:21 PM
99Bluz28's Avatar
McMaster-Carr ; damn near has it all!
pm sent.
Old 05-27-2011, 06:35 PM
Jontall's Avatar
Get rid of the spacers and use these extra thick gaskets... They make life easy.
http://www.hinsonsupercars.com/p-128...ver-seals.aspx
Old 05-27-2011, 07:06 PM
How thick are the gaskets? They may be all I would need.
Old 05-27-2011, 07:07 PM
pm sent.
Thanks for the suggestion. I'll look into that too.
Old 05-28-2011, 05:08 AM
Jontall's Avatar
Here you go... No spacers needed with these and they're only $21 + shipping.
Attached Thumbnails valve cover spacer gasket material-ytvalvecovergaskets_1.jpg   valve cover spacer gasket material-ytvalvecovergaskets_2.jpg
Old 05-28-2011, 06:46 AM
I'll have to take my valve covers off and figure out how much space I actually need. I have T&D shaft mount rockers, I think they are a little taller than the yella terras but not much.
Old 05-28-2011, 01:03 PM
UMI Performance's Avatar
We have the replacement gaskets, they are inexpensive. Shoot me a PM and I will get you a price on them Monday or Tuesday.
Thanks!
Ryan
Quick Reply: valve cover spacer gasket material
