Voltage drop at high rpm accel or decel...not the alternator
Alright i started noticing at night time my lights would dim when I would go wide open throttle. So figuring it was my AC Delco reman alternator I installed last year, I contacted the company I bought it from and they warrantied it. They sent me another reman and I installed it...same thing...So i figured hey thats weird but maybe 2 bad remans in a row, so I then requested a brand new alternator. They sent me one which I just installed and I am still having the same problem. I also have a brand new battery, and my buddy whos a mechanic tested my grounds with a multimeter and they tested out ok. So I am at a loss....anyone else with this problem or something similar? Any suggestions, comments, or anything else is extremely welcome. Thanks.
lol 6800? Wow....I hope its just belt slip mine does it after 4k at 50%+ throttle.
it is your alternator. the diodes in it a too small to accept the inrush of voltage. there is a writeup this subject called:my constant alternator woes or something like that. i'ts here in ls1 tech, maybe a sticky it explains it completely. truck alternator 145amp type will cure it i did mine a new one. bone yards have them also as an option. over rev frys diodes.. great article i wish you good luck and hope this helps. the oldman..
That doesn't mean the contacts are good. Those connectors go bad. Get a new one just for good measure AC Delco PT1136.
That is my thread about the alternator failures. I've seen it all I think.
It sounds like belt slip, but our cars normally throw belts when they slip, mine did. I put on a high wall tensioner pulley and it stopped the belt slip and the belt jump. It put a hair more tension on the belt.
Try this, it's cheap. https://ls1tech.com/forums/generatio...swap-pics.html
Can you hold the revs while parked and see the voltage drop? If so hold ratchet on the tensioner bolt while someone revs the engine, apply more tension to the belt while revving it and see if the voltage comes up, if so the belt is slipping, if not your alternator is dropping voltage.
is there a schematic or pics that show the exact routing of that exciter wire? I might get a new one and run it and leave the stock one alone stuck out of the way since its all wrapped up with other wires in a wire loom.
Thanks man I think im going to have to try that. As for the connector it looked fine when I had it off, and the car only has 50k and from the looks of it underneath, was garaged for its whole life. It also seems like belt slip to me, the only thing is the belt looks fine...But before I buy a new tensioner I might as well try that buick pulley.
All the parts are old, it doesn't matter that they only have 50k miles when they are 10 years old man.
It would be a good ideal to do a new belt and tensioner along with the connector. I also like the buick pulley if you are revving the engine high, it helps keep the belt on.
Since you drug this old *** thread up.....
You sir are an idiot. An fbody doesnt require a "truck alternator", even one with EXTRA electrical demands much less a stock vehicle. Giving poor advice and spewing false information just makes people dumber.
Thats funny, cause I've run a stock fbody alternator for no less then 11 years and at times with more electrical demand then stock with zero issues. Having someone throw a bigger alternator at the problem isnt the correct answer. Sounds like he has a clear ISSUE with the car, charging system, and associating wiring/cables. I would fix that first! Properly diagnose the car first. 99.99% of cars do not need bigger alternators.
00pooterSS went thru his vehicle with a fine tooth comb and found nothing wrong anywhere. But he kept going thru alternators until he put in a used 145 amp truck unit. Now maybe he didn't need the 145 amps, but there is something different about the truck unit that keeps it alive where the OEM units dies every time. And being a long-time tech, he should know what he's talking about. You have a point; no one needs the 145 amps, but there is another aspect about those alternators that is tougher than the OEM units
