What's a good 3" resonator? LS1 swapped Nissan 240sx. Current exhaust is 1 3/4" headers to 3" collectors to hi-flow 3" Y, out to a single 3" Magnaflow. It sounds amazing when I'm on it full throttle, but part throttle and driving around town is starting to bother me now. It's a good bit raspy at low throttle/rpm's. I just want to put a small resonator between the Y and Magnaflow to cut down on the raspiness. What are some good ones? |
I've got SLP LM II's in my true dual set up. Alot of raspiness comes from the merge in the Y to though. |
A resonator won't really help as it's a straight through pipe. With out cats or a y with a flowmaster style merge your best bet is to squeeze in another small muffler somewhere. I'm not that familiar with the exhaust layout on 240's so maybe someone else will be able to make a recommendation. |
They are right about the Y merge. Post a pic of the merge and how much room you have. I would reccomend a Powerstick. I believe they have different lengths. |
Originally Posted by SH1ZN1T
(Post 15894966)
I have room for a 16". I'll try to get a pic soon. I'm replacing some stuff on the front end right now. I might have a pic in my photobucket though. |
You might consider throwing a powerstick in there, but install it against the grain. Not trying to contradict what '00 Z is saying, but I know for the GMMG guys it's killed their rasp. Hell, you already have a great merge, and the powersticks now have a true 3" center section, so no necking down like a Sweet Thunder. |
When I said small, I just meant I didn't want to cut down on the nice tone much. I didn't mean size. As you can see, there's plenty to work with there. :) |
I added a 12" dynomax bullet to my magnaflow and it cut down the raspiness quite a bit and it still flows straight through:nod: |
Originally Posted by dr_whigham
(Post 15897932)
Powerstick? Who makes them? |
dynomax bullet. |
Originally Posted by sepsis
(Post 15901216)
Powerstick? Who makes them? I went to that website & sweet thunders. Classic Chambered is the only one that has a true 3" inside section, with a 3.5" OD; Could fit that anywhere. Sweet thunder DOES neck down, however. From their website: In this basic group of chambered mufflers, the inner baffle tubes are the same diameter as the inlet and outlet. However, 3" inlets and outlets come with 2½" inner baffle tubes. Anyways, what sucks (for me) is Classic Chambered makes a true 3", but NOT in stainless. Sweet Thunder makes them in stainless, but with the smaller ID.... :bang: |
| All times are GMT -5. The time now is 04:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
