Driving without front o2 sensors
Is it okay to drive a few miles without any o2 sensors? will the car even run? reason i ask is because i forgot to order o2 sensor extensions for the front, i was planning on getting rid of the rear o2s and just having them tuned out and didnt realize until it was too late that i needed front o2 extensions for the longtubes.
Thanks in advance
Thanks in advance
Yes the car will run, albeit rich.
The stock tune runs like that for the first few minutes after a cold start, so you will be fine driving it for a few miles. On a cold day, it will take quite a bit to warm up the engine enough for the o2 sensors to start working, but you don't see cars coming off a cold start have problems moving around.
+1, you should be fine on a short trip. long term driving without the front o2 will result in fouled plugs and eventually a pretty gummy combustion chamber because the computer will read no fuel in the exhaust and therefore it will inject more to compensate. rear o2's will throw a emissions code that basically says your cats are bad.
