lose power with FAST 102 from VS ls6 Intake
#41
I am.. I agree with the what 427LS7HCI said about trying a 92mm tb & I said the same in your dyno thread.. The fact that you're loosing power below & gaining at peak sounds like poor intake velocity with the big 102 tb. Worth a shot if you know somebody who has one they'd let you try.
#44
The new design of the 102's is a removable runner, removable top , right? Any chance you have an internal leak? Also leftover casting flashing & shrink variations could be worse in one intake than most.
Just trying to think inside the box here.
#45
what would an internal like sound like? any idea of how to identify this? i'm thinking about doing smoke test on my car, do you guys think it'll be useful?
there's one runner that makes a "wooss" sound but i'm thinking it's just more air compared to the ls6 intake
#46
Do you have a data log from the dyno run from a WOT run of the LS6 intake? You need to compare the MAP kPa reading between the (and using key on values) two which gives a good indication of incoming airflow. It should be higher at WOT for the FAST intake. I would also ditch the GMS MAF and go with a new GM 85mm MAF.
#47
From dyno thread.....you need to get ahold of a GM 90mm MAF. 100mm is just a waste on your car and there harder to tune.
Here is the log from his last pull with the graph he posted on the Mustang Dyno. And it's a stock 75mm MAF center section with afermarket plastic MAF ends.
#51
you have it slightly incorrect there...
its not that he doesnt need it.... its always good to get more air into the engine any way you can..
the problem is that he is not set up to use it effectively..
I agree.. His setup cannot use a 100+mm MAF properly...
big or small cubes doesnt make a difference...my 346 showed power gain going from a 90mm MAF to a 100mm MAF, but I also had the proper amount of tuing in front of the MAF and got the airflow smoothed out before it went thru the MAF.
#52
sound:like i said i'm planning to put the saxon airflow straightener to help smoothen up the air flow. what do you mean that my setup can't use 100mm MAF properly and you can?
#54
#55
I see what you guys are saying. I have the MAF coming in anyway and I'll sell it to get 92mm TB and 85mm MAF hope that will help me gain my mid range power back.
Thank you for the inputs.
#59
It's probably too late for this, but if you can sell the F.A.S.T. intake manifold do so.
Then contact TPiS and send them your LS6 intake manifold. TPiS will convert the snout of it to accept the 90mm GM throttle body. Your cost will be approximately $400. The result will be more power than a F.A.S.T. 90 mm, better low and mid-range torque, and you will save money.
