LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Slammed 01 Formula: Need Headers That Won't Scrape! (https://ls1tech.com/forums/generation-iii-external-engine/1545929-slammed-01-formula-need-headers-wont-scrape.html)
Tubba May 11, 2012 12:30 PM
Right now my tunnel bar sits exactly about 2"-3" off the ground and I scrape/throw sparks even on the freeway when there's small dips....
Is there anyone who makes a header setup that's tucked in enough similar to stock manifolds?
Or I'm I out of luck?
Thanks in advanced.
Don't Post Dumbassness About Lifting My Car....I Don't Wanna Hear It.
metalmilitia606 May 11, 2012 12:33 PM
The only thing I can think of are some shorty headers. I also want to say that either ls2 or ls3 stock manifolds flow just as good as some shorty setups. Someone correct me if I'm wrong.
babbage1109 May 11, 2012 12:39 PM
When you're running a 3 inch round collector on the header all headers are going to sit the same. Maybe you should look into an oval setup
GoFastKid May 11, 2012 12:41 PM
Here's an idea, put a different set of springs on it and problem solved. These aren't Honda's or VW's. :rolleyes:
Latch May 11, 2012 02:06 PM
I would recommend BBKs, plus their Y is only 2.5" so that helps quite a bit.
99Bluz28 May 11, 2012 02:52 PM
You'll want the BBK LTs & ory-pipe, and make sure you install poly motor mounts so you can tuck it up as far as possible without banging the floor board. There's also a few modification you can do to tuck the BBK Y-pipe up even further.
99Bluz28 May 11, 2012 02:55 PM
Is Your tunnel support bar stock, or a low hanging aftermarket one?
Tubba May 11, 2012 04:36 PM
Thanks for all the input
And my tunnel bar is Low hanging, its red but I don't know what company
Tubba May 11, 2012 04:37 PM
It loves making out with speedbumps
ramairetransam May 11, 2012 06:19 PM
do like i have , i have mac mids , not the best power but better than stock or shorties , i would do mac mids if i were you .I have them and no ground clearance problems .
Tubba May 11, 2012 06:44 PM
Can I get a part number or link? Please
ramairetransam May 11, 2012 06:50 PM
http://www.ws6project.com/user_stor/...-pipe-no-cats/
99Bluz28 May 11, 2012 06:58 PM
You can also get the BBK LTs here:
http://www.ws6project.com/user_stor/...stem-ceramic-/
Tubba May 12, 2012 01:39 AM
Thanks alot is there a power difference between the Mac and bbk??
ramairetransam May 12, 2012 08:21 AM
no idea , im pretty sure more people run the macs , but the difference can be too much . I mean were giving up a bunch not having lts .
Blownbayou May 12, 2012 09:10 AM
bbks and ory here...... easiest install and best clearance
95LTXZ28 May 12, 2012 09:38 AM
If you want a long tube header, im going to also suggest the BBK setup also.
MonmouthCtyLS7 May 12, 2012 12:27 PM
I still scrap with Mac Mids, not a lot but I still do...and there proven performers...some have switched to LT's and gained about 5 hp lol
bad67ls May 12, 2012 12:37 PM
spend the money on a set of american racing headers. thy are so close to the floow on my 67 camaro i had to use band clamps to attach it to my exhaust. you cant even see them from the side of the car.
and yes, they make them all that high. my friend just put a set on his second gen camaro and its the same way.
lemons12 May 12, 2012 12:44 PM
BBK... No shorty or mid will flow equal to a LT.
© 2026 MH Sub I, LLC dba Internet Brands
