LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   lingenfelter's 2 step (https://ls1tech.com/forums/generation-iii-external-engine/1549144-lingenfelters-2-step.html)
bumpin_records May 21, 2012 05:52 PM
I have a lingenfelter 2 step LNC-003. Do I use both stages or just the first stage. What would be the advantage of using the second stage? thanks
Ryan@Lingenfelter May 21, 2012 08:22 PM
You could use 1 stage or both. It is completely up to you. Some people like to use the secondary stage for the burnout box or as a rev limiter (some aftermarket engine management systems do not have a built in rev limiter).
Ryan
bumpin_records May 22, 2012 08:00 AM
Ryan
oh ok,GREAT!! what do you recommend? Thanks for the info as well.
© 2026 MH Sub I, LLC dba Internet Brands
