Texas Speed Long Tubes! Easy Install, Thumbs Up!
Old 07-20-2012, 10:48 AM
SLP IROC-Z's Avatar
Thumbs up Texas Speed Long Tubes! Easy Install, Thumbs Up!
I installed my TSP 1 3/4 Long Tubes in m 99 Z28 last night, very very easy! after reading around i was under the impression id have to remove the steering shaft and jack the motor up on the drivers side so i did the drivers side first and the header slipped right up and in where it needed to go without having to remove or disconnect anything, the passenger side was just as easy! i was really impressed and glad i didnt have to break my ***** installing them. i did mine on our rotary lift. i already have poly motor mounts and the little heat sheild that bolts to the motor mount on the drivers side is removed so that may have helped. thumps up to TSP for such a nice and great fitting product!
oh and the car sounds insane now as well!
Old 07-20-2012, 10:54 AM
Sales1@Texas-speed's Avatar
Thanks for the kind words! Let us know if there is anything else we can help you with.
Old 07-20-2012, 10:55 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I am glad your install went smoothly! Usually the 1 3/4" slide right in, it's just the 1 7/8" that need a little more work on the driver's side typically.
Let us know if we can help with anything down the road!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-20-2012, 01:05 PM
SLP IROC-Z's Avatar
ground clearance is great as well!
Attached Thumbnails Texas Speed Long Tubes! Easy Install, Thumbs Up!-z28-173.jpg   Texas Speed Long Tubes! Easy Install, Thumbs Up!-z28-172.jpg   Texas Speed Long Tubes! Easy Install, Thumbs Up!-z28-171.jpg
Old 07-20-2012, 01:14 PM
Mike Morris's Avatar
Nice!
Quick Reply: Texas Speed Long Tubes! Easy Install, Thumbs Up!
