PCV Crossover Tube
PCV Crossover Tube
How important is it to have a PCV system linked to either side? I bought these Holley Valve covers for my LS1 motor but there is no second fitting in the back of the passenger side valve cover for the crossover tube (see below). Is it possible to just use the two vents somehow and make these work on the car? Thanks in advance!
-Jake
-Jake
Sure. The one on the left would go in front of the throttle blade. The one on the right will go into the plenum behind the throttle body. Now if you have a catch can you will have to add that in to the line from the one on the right. Also do you have a vent on your valley plate?
I'm not sure about the valley plate vent. Aside from the heads and cam, its the motor from a 2002 Camaro.
