tach help??
Old Dec 5, 2012 | 08:09 PM
98camaro53187's Avatar
Default tach help??
hi i have a 98 ls1 i wanted to know which coil or wire do i hook the green wire from my tach. any help would be great thanks.
Old Dec 6, 2012 | 04:22 AM
garys 68's Avatar
tach runs off the ecu. seach the conversion forum for wiring diagrams and pinouts for your year/engine
Old Dec 9, 2012 | 09:29 PM
gMAG's Avatar
Should be pin #35 White wire (Engine Speed).
There is another pin #35, which is LT GRN.
Not sure which row of pins (blue conn/red conn) on the ECM.
Also, you may need a 'pull-up' ckt to create a useful signal for the tach.
Thanks to "FastKat" for the diagram, & the POT idea.
The WHITE WIRE-pin 10, noted in the diagram, is from a different year.
As an alternative, & more exact circuit, you could wire a POT (variable resistor) in, instead of the fixed value 680 ohm resistor. Turn the POT until you get a good tach signal. Then, remove the POT & measure across it, to find the exact resistance threshold which operates the tach. Replace the POT with that resistance value.
