Bolt-on gurus I need your help.
Car is currently stock and I am planning on doing long tubes,YT valve spring,LS6 intake(or suggest me something better?) and a cam.I'll probably go G5X1 or G5X2.
What can I expect as far as RWHP?Should I consider a head swap?
Budget is limited 3-5k parts only.
Thank you.
there are more ways than one to skin a cat. what are YT valve springs?
with the x1 or x2 and ls6 intake i think you'd be looking at mid-high 390s hpwise. you could go with a fast setup, but i think this relates back to the end goal as you could have a nice set of ai altered heads for the same money.
car a m6 or a4?
car a m6 or a4?
If I hit 380 RWHP or 410,then I'm ok with that.I just want to get the most out of my setup.Well spent money produces good number...
Car is M6.
Staying stock heads and wanting the best performance, I'd definitely look into a FAST intake as suggested, but I would get a custom spec'd cam, check out Pat G/EPS cam threads. They can make fantastic power without being huge.
Car is M6.
i found a new in the box gen 1 a&a corvette procharger kit.. $1200 steal with injectors and everything...
we installed everything, including blower cam, new springs, and essentials, new fuel pump, got it tuned..
long story short, car has 190k original miles on the block, 550 rear wheel... and we did that on a really low budget
