Turbo'd set up with no pcv... why? We recently worked on a twin turbo'd corvette and the previous owner had removed the pcv, plugged the valve covers and intake and used two open elements. Is there a reason they done this? I've seen pcv systems on turbo'd cars before. We plan to go back with a catch can etc. if they're wasn't a reason. Any input is appreciated. |
The first time getting my car tuned after going forced induction I pushed the timing cover seal out of the engine on the dyno. It blew 5 quarts of oil everywhere and almost gave me a heart attack. The stock PCV system was not enough to keep up the crank case pressure. I removed my pcv system and I now vent all 3 rocker cover ports to a vented catch can. This has been working for me for the last 5 years or so. |
On a pressurized motor, there is no reliable vacuum source (intake can swing to either side of ambient pressure). So nothing for PCV to draw to. Unless you ran a full time vacuum pump or something. |
the intake is a reliable vacuum source. the intake is in vacuum for 99.99% of its life. i make cans that work with full factory pcv intentions but they also can handle that .01% with ease :) |
Originally Posted by MIGHTYMOUSE
(Post 17364824)
sent to ya! |
im really surprice id didnt blow up !!!!!!! |
that so much crankcase pressure |
I have one of mightmouses cans that im installing on my turbo lq4. I tested it out today using my air compressor and it works as advertised. |
| All times are GMT -5. The time now is 04:32 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
