Need help asap..AIR sylenoid info
So I'm trying to replace what I call an "AIR injection vacuum sylenoid" and idk if that's even the technical term parts stores or GM would use so if any body can give me correct terminology on this part an where the F I can locate one that would be apprichiated thanks fellas!!
Here's a pic of the exact piece I need...
Did you try www.gmpartsdirect.com and look at the exploded views? I looked and it looks like a Purge Valve from the emmision system.
Go check that out, it was item #10.
Chad
Chad
Chad
Chad
I can't find that part number I see the pic and info but no PN
Dude your a badass def a true rodder in my book! I ended up getting one but If it leaks on my smoke test like the last one did at the seam ill def PM u and get those from ya no doubt..thanks again man I really appriciate it! Take care thanks fellas!
