Fast 92 install AC problems
Old May 27, 2013 | 04:23 PM
sway99bird's Avatar
Default Fast 92 install AC problems
I recently installed a Fast 92 from Vengence Racing and there was no spot for the vaccum line just for brake booster. So what did ya'll do ? I called Vengence and they told me just to cap it off I had no idea it was for the AC vents. Any information will be help full and pictures to see what was done different or if i'm completely blind.
Sway
Old May 28, 2013 | 09:33 PM
sway99bird's Avatar
Bump.....
Old May 28, 2013 | 09:48 PM
babbage1109's Avatar
They all should have a plug in the back of the intake. Is it broke off?
Old May 28, 2013 | 09:51 PM
sway99bird's Avatar
No I bought it new it even said in the instructions to cap it off if I remember right and when I call Vengence they said the same thing.
Old May 28, 2013 | 09:53 PM
Weird. Lol. The original 90s have that provision. If anything drill a small hole and get a fitting from the hardware store and tap it for the vacuum line
Old May 28, 2013 | 10:02 PM
1320Chicken's Avatar
I just installed a fast 92 and it has the nipple for the vaccum line. Something sounds screwy.
Old May 29, 2013 | 03:01 AM
99Bluz28's Avatar
it should be right on the other side of the passenger side rear intake mount bolt hole, that's where mine is.
http://i34.photobucket.com/albums/d1...8/IMAG2041.jpg
Old May 29, 2013 | 03:20 PM
Marc 85Z28's Avatar
I don't understand what's so difficult here? Take the cap off the vacuum port and connect the vacuum line!
Old May 29, 2013 | 07:23 PM
sway99bird's Avatar
Ill take it off and check again..
