Goodies arrived today!! - install/results thread w/pics
#42
Don't worry about the dyno numbers...if it pulls good, and feels good, go with it. Take it to another dyno and run it if you're really worried about it, but considering it made LESS, obviously the dyno is off.
Drill mod is good but just go ahead and install a Tick Master! Lol.
I gotta take it easy on the spending on this thing for a bit...drill mod is free so I figure I'll try that and see what it gets me...will also probably wrap the line with some heat reflective tape
#44
I laid down 343rwhp and 353rwtq with my old ws6 that was an a4 with some cheap eBay headers and other bolt ons (25% underdrive, ported throttle body, etc). You should be able to hit those numbers easy.
#45
To the OP, if in the end your clutch is crapped Monster has $125 off their clutches right now, one of their clutches would compliment your setup very well.
#46
After a couple pulls, you could hear the brakes on the dyno squeeling as the tuner was rolling into first for another pull, so he was almost certain that the brakes were engaged when they shouldn't have been
#47
Was there any warning from the shop that did the tuning that their dyno might give off low number because of it's issues? I mean I guess it doesn't matter too much as it's still going to be tuned the same, but hell, it would have been nice to know beforehand that the dyno might be reading low numbers at the end of the tuning process. Keep us updated on track times, and if you do give in and take it to another dyno, let us know those results too. Congrats on getting it all together. The feeling of mo' powa' is always a good one.
PS - That is one clean underbody... so jealous!
#49
And thanks, it's a bit of a garage queen as you can tell
#50
Okay guys, got the drill mod done tonight...
First of all, let's take a look in the reservoir...isn't it nice in there?
Master cylinder was a PITA to get out but it was persuaded:
Drilled out the line with a 1/8" bit:
Decided to hack up my floor to make bleeding a one man job...used a 1" holesaw, luckily got it first try:
Peekaboo!
Had to slighty bend the bleeder screw upwards to get a 1/4" drive 7/16" socket on it...
So before installing the M/C, I bench bled it and wrapped the slave line in aluminum foil tape...without touching the bleeder, the pedal felt good, but I figured I would still have air in the system...so I bled a few times, went through a couple reservoirs of fluid using DOT 4...pedal still felt good, so I went for the first drive - pedal sticks worse than before...bled it a couple more times - pedal still sticks, again only after a high rpm pull...I didn't even attempt to bang the gears...had to pump the pedal a bunch to restore it...
Sooo, either I have more air in the system that doesn't wanna come out, or one of the hydraulic/clutch components has suddenly taken a dump...
the car shifts fine when cruising, pedal does not stick at all...only @ high rpms up does it seem to stick...
I'll try bleeding it a couple more times, but I find it hard to believe my 60000km (40000 mile) clutch assembly is failing
What do you guys think?
Peekaboo!
#52
Oh well, I'll try a few more bleeds, and if she doesn't wanna cooperate, I guess it's time for a monster stage 2 package - $cha-ching$
#55
Okay guys, Tick master & speed bleeder is on order...if it solves the issue, sweet...if it's my clutch assembly or slave, I'll be replacing the whole shot anyways, so I'll already have the Tick master
Martin, I hear nothing but good things about your products & services, so you have my business on this one
#56
Update,
Got the Tick master and speed bleeder installed:
Nice quality kit
Bench bleeding the master, without a vice
Here's the master bolted up, I actually found it a little easier to install than the stocker, because you can remove the adjustable rod
Didn't realize until I tried to install the speed bleeder that the trans needs to come out...wasn't as difficult as I expected though
All that for this little line...definately worth it though, makes bleeding a breeze
Also gave me an excuse to replace that 11 year old trans fluid
Here's the stock LS6 clutch...didn't notice any damaged or bent fingers
Did notice this stuff hanging off the PP...looked like crushed up leaves to me, would this be friction material??
At this point, I was really tempted to put the job on hold and order another clutch setup, but I decided to keep going, get this master in and see if it fixes my issue
Got everything back in, and started bleeding & adjusting...
I started with the pedal close to the floor, maybe had 2-3 inches of travel...car would go into 1st okay, but shifting while driving around felt notchy
I adjusted a few more times until the clutch pedal and brake pedal were even...car drives & shifts better, however still has some notchy shifting and pedal still sticks a little between high rpm shifts
I have bled the system numerous times with the speed bleeder both under the car and submerged in fluid @ the reservoir so I'm almost certain there's no air in the system...
Again, the issues seem to improve the higher I adjust the pedal, but I don't want to risk over-adjusting and damaging the pressure plate...
Nice quality kit
#57
I think I got it...took the spring off the clutch pedal, adjusted the master another turn so the clutch sits just a tad higher than the brake
car drives much better, sticky pedal is gone
Definately recommend this product to anyone having these issues...it's not the cheapest thing but if you don't wanna ditch your stock clutch yet, this is the way to go
Next up will be the UMI LCA relocation brackets, gotta re-seal my diff cover, and then off I'll go to the track to see what she does...
maybe get back to Champion for another dyno pull soon too
