New ls6 intake, what do I need to delete EGR
I have a 98 ls1, but have an ls6 intake on the way. I need to delete the EGR, can anyone tell me exactly what /how many plates I will end up using to delete this?
Thanks!
Thanks!
An LS6 intake won't have any ports that needs blocked. The only port that'll need blocked will be on the bottom passenger side of the manifold/header. If your deleting the AIR at the same time you'll need 3 of the little metal plates. If not just the one. Remember your ses light will come on when you ditch the EGR stuff to.
Just what everyone said, you'll just need the plates for the exhaust manifolds, or wait to put the intake on until you do headers (if you're doing headers) and buy headers with no emissions hook ups and you won't have to buy plates. If you delete your AIR too there's a bracket holding the pump inside your front bumper. I went all out and took EVERYTHING out, the bracket, the pump, all the hoses, the little bracket on the back of the block, the relay, the fuse, etc. Be careful when doing this swap, the oil pressure sending unit gets broken by the brake booster line if you're not careful, easy to replace but $60 for a new one.
Thanks guys! I already have headers, so I'll need the plates. The ls6 intake is USED off of a Camaro that had 60k on it. From my understanding, the ls6's never had egr so there is nothing to block on the intake itself, correct?
And thanks for the tip on the oil sending unit, I'll be sure to be careful!
Yea, they're nothing on the intake that will need to be blocked. Only the one port on the bottom of the header on the passenger side. I would soak those bolts in something a few days before you try to unbolt them. I've broken a lot of them off. I actually ended up pulling the headers and just welding up the AIR and EGR bungs. You'll also have to chisel the ribs off the bottom of the intake unless you have 01-02 coolant lines. Might not be a bad idea to remove the knock sensor seals and waterproof them with rtv while the intakes off.
Thanks again
