LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   What's ths and where does it connect? (https://ls1tech.com/forums/generation-iii-external-engine/1668863-whats-ths-where-does-connect.html)
RealLiveMD Aug 13, 2013 10:42 PM
1 Attachment(s)
I just reassembled my engine. On the driver side there is a connector over rear third of the valve cover. It connects to a sensor that is held in place by a little slit on the intake. I small vacuum line appears to run from it and connects to the t in the pic. I'm just not sure where to connect the t. I'm guessing it was part of my air system but that's been gone for years. I'm holding the t in the pic.
jsteele90 Aug 13, 2013 10:53 PM
just plug the tee its part of the AIR system
RealLiveMD Aug 13, 2013 11:12 PM
Thanks
RealLiveMD Aug 14, 2013 10:07 AM
The more I think about it. I didn't have this plugged off before I removed the heads to change the lifters, so can you guys think of anywhere else I would have had it connected. Im wondering why I didn't get a vaccum leak if I really jut had it open to air. My buddy was helping with the tear down so Im not sure.
demonspeed Aug 14, 2013 11:36 AM
The T should actually be behind the intake manifold. The top hose is the only line from the AIR system (and should subsequently be capped off). The other vacuum hose goes to the HVAC system (runs to the passenger side of the car) and needs to be hooked up to the T so that it can draw vacuum from the manifold to operate the mixing doors.
RealLiveMD Aug 14, 2013 01:52 PM
Ok Im a little confused. Is there a spot on the intake that has another vacuum. When I replaced the intake. There was a vaccum line coming from the passenger firewall that I connected directed to the intake. The map sensor was never removed and I just reconnected the switch. The big vacuum went to the brake booster.,,. and I reconnected the tall breakable sensor, (i think its oil pressure. So where exact would I plug the T. Right now while difficult to tell from the pic. I have the t hose connected to the switch and hose shown in the pic but thats whats leaving the T as a with a femal and male plug.
demonspeed Aug 14, 2013 03:56 PM
Ah... ok, I see now. That's not behind the intake; rather, you're saying it's along the side of the intake/above the valve cover. The only other vacuum lines I am aware of (sans the HVAC line and booster line) are for the AIR system. I don't know that I recall another T fitting anywhere, though.
ponyhater27 Aug 26, 2013 05:21 AM
The T fitting goes on the back of the intake and one side goes to the HVAC the other connecting to your AIR solenoid. The AIR mechenism is on the side of the intake above #5. You can plug the HVAC line coming from the passenger side behind the computer directly to the rear of the intake and delete the AIR.
© 2026 MH Sub I, LLC dba Internet Brands
