LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Would these Flowmaster's work for true duals? (https://ls1tech.com/forums/generation-iii-external-engine/168923-would-these-flowmasters-work-true-duals.html)
2_wacko May 6, 2004 10:38 PM
I have not seen these muffler's on a F-Body yet would they work or are the too big.http://www.flowmastermufflers.com/cg...ml?id=hK2UYmMv
2002 Trans Am May 6, 2004 10:40 PM
Flowmaster usually aren't likened by the forum members
tim99ws6 May 6, 2004 10:45 PM
no, not flowmasters....it's the weak low flowing 80 series....Most all their other mufflers flow great. According to flowmaster, the 80's series is the best they could do to be able to stay 50 state emissions legal and still be dual exhaust....now if they changed it, they'd be assaulted for copying other manufacturers.
I think those mufflers design from the outside looks great. Only real problem is oval tubing is a little more expensive than your average circular tubing. See if you can get some pics of the "guts" of the muffler...that's be interesting....these look to be some kind of a circle track muffler...
good find
Mike94ZLT1 May 6, 2004 10:58 PM
I use this Pn from summit. FLO-325508. They are 2 chambers, 11 inches long, 8 inches wide, and THREE INCHES THICK!! most normal flowmasters are 4 inches thick. These are the same thickness as bullets, they sound mean as hell but arent overbearing.
© 2026 MH Sub I, LLC dba Internet Brands
