LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Pacesetter LT's question (https://ls1tech.com/forums/generation-iii-external-engine/169529-pacesetter-lts-question.html)
Racer99Bird May 9, 2004 02:10 AM
Was wondering if it is better to get the Race ready headers or the smog ones??? Don't care about passing state or not either if that helps, and also is their off road y pipe any good, or should I get one custom made???
ls1rocker May 9, 2004 02:59 AM
id go with the emitions ready ones, just make ya some block off plates, just incase some day you need to use em
and i hear the Y pipe is crap, i went with true duals dumped at the axle, man it sounds damn good, so my votes for the emitions legal headers and true duals good luck man -matt
OnyxY2KSS May 9, 2004 03:26 AM
well i have the race pacesetters and ORY, i just deleted the codes and no more SES and btw the y pipe worked fine for me, no probs :thumb:
Blacker May 9, 2004 04:48 AM
I bought race headers from QTP. I figure it this way, that is 3 less welds that can break. My Hooker LT's broke an air tube weld on the driver's side and making the car useless.
jamnut May 9, 2004 08:19 AM
I'm running the Pacesetter Race Headers, getting rid of all the emmissions crap really cleans up underneath your hood.
Simp May 9, 2004 10:05 AM
Werd.
If you have a car with EGR just get some JB Weld and some sheet metal and fab up a ghetto style EGR block plate. The AIR system is also easy to remove, aside maybe from that piece of shit pump, although I'm sure it would be easy with the right tools.
Basically, if you want to keep your emissions crap, get the emissions headers. If you want to clean all that crap up get the race ones and remove all the rubbish. I've had my SES light on for 3 months since doing an AIR and EGR removal. The car runs fine and thif you can deal with the site of the SES light you'll be straight not getting the codes deleted.
Larry May 9, 2004 10:15 AM
Better get a custom made Y pipe or this is what you get.
http://www.mustangmods.com/data/440/pacecoll.jpg
zchgla May 9, 2004 11:57 AM
Originally Posted by Simp
Werd.
can someone explain all this to a big dummy (me)? what is EGR? what is AIR? what emessions crap is there to remove?
zchgla May 9, 2004 09:20 PM
anyone?
Jpr5690 May 9, 2004 09:25 PM
The Air And The Egr Are The Pipes That Run Into Your Headers The Egr Or Exaust Gas Reguration Valve Takes Connects Yout Intake Manifold To Your Primaries On The Header While The Air System Pumps Air Into Your Primaries To Help Heat Up Your Cats. If Your Doing Off Road Headers You Can Remove All This Crap But You Will Start Throwing Codes ... You Can Live With The Air Codes But Im Not Sure If The Egr Codes Will Effect Peformance One Way Yo Not Throw An Air Code Is Just To Leave The Air Pump In And Just Dicsonnect All The Plumbing From It This Is What I Did And All Is Good
zchgla May 9, 2004 10:14 PM
so the EGR is just the tube, and AIR pumps air into the primaries, got it. does anyone know of you can remove the tube and the pump? i met a guy that said he took something or other off of his lt1 T/A and he was saying that the exhaust got more black and smelling like crap because he took it off, is this what he removed?
Jpr5690 May 9, 2004 10:35 PM
Probaly His Cats
jbvic15 May 9, 2004 10:54 PM
Im on a cheap budget, is pacessetter the way to go for LT headers, and if so the y-pipe...in out?? Get one custom or what? Increase HP/torque a good amount, make sound better? you tell me
© 2026 MH Sub I, LLC dba Internet Brands
