Mightymouse Solutions 'Black' PCV catch can install
#41
- NEW 3rd port with Sight Glass!
- Dual Pass Filtration
- Black Anodized Coating
- O-ring -AN Fittings in-6,-8,-10, 12, 3/8" and 1/2" barbs
- 'Drain in place' Knurled Thumb-Screw Drain
-'PRO' Bolt Clamp style mount
-Integrated High Flow 'Boosted' crank case pressure relief valve.
and most importantly the ladies love 'em!
#43
i'm not sure which MM one to get either. I have the 2 heater hoses coming from both valve covers so I want an MM can with 2 inlets, and then one going to the either the tbody fitting or the one right behind that on the intake (not sure which one of those it should go to actually).
currently, no PVC installed. its got 92mm intake. don't see any tubes from center valley.
#44
#47
You can see what I'm talking about here:
#51
Yup unless you're making a ton of power. Just T them together then run to the intake port right behind the TB and then the line from the valley cover to the lid. You can see how I ran mine here. I did run a hose from each valve cover tho. But the T would be fine I would think. I just used a 3/8" barbed fitting. I drilled a hole just a hair smaller than the threads in the lid and tightened it into the lid by hand. Nice and tight
#52
got the new pcv gen 4 can in today. ordered the ls head mounting bracket. Question is what size bolts are you using to mount the bracket to the head. Size, length, thread pitch?
#55
Was just wondering on the black pvc can ... I bought mine off a guy and he had none of the info ... pcv is on the highest port and going Into the center chamber between one way breather and lower element ... my qestion is on my turbo silverado I don't have a port or airfilter on the inlet side ... so will it be okay and safe to hook to stock port on top of intake and run both valve covers two the other two ports ? ... if not them how should I hook up to keep the pvc system as stock as possible .. oh and stock gen3 Valley plate (no port)
#56
A PCV system is the constant turnover of regulated 'dirty' air being drawn out to the intake manifold which causes 'clean' air to be drawn in another port on the engine to replace it. You cannot have a PCV setup without this fresh air 'in' port. This means that the 'dirty' side fitting needs to be large enough to support your power level. MMS has options for this like the oil fill adapters. The dotted lines are options on the diagram:
#57
One bit you might notice if you don't use a PCV style is that your engine can collect a lot more moisture in the crank case, the vacume/suction helps evacuate water vapor as the engine warms up. If your running methanol injection its even worse. This is no big deal on a race engine that's getting fresh oil every weekend but for a street driver PCV/CCV is mandatory for me..
Let than .02 bucks worth,,,
YMMV just a thought..
#58
I replaced my RX can with the MM since i was getting blow-by with it. Very dissapointing considering how much i paid for it.
Not a fan of the MM bracket since it will scratch the can once tightened so i put some gorilla tape on the inside of it. Paint was so so, spotting all over the finish looks like poor prep. Custom colors in powder coat would be a nice option i would pay for. Other than that it looks like a solid setup, no testing yet as my car is in storage till may.
