What is this thing? (Intake manifold piece)
Old May 10, 2014 | 01:11 PM
TMLoftis's Avatar
Default What is this thing? (Intake manifold piece)
Trying to figure out what this thing is, the thing with the green cap where it attaches right behind the throttle body with the tubing running out to the rear of the engine?
Old May 10, 2014 | 01:55 PM
LS1MCSS's Avatar
Canister purge valve. Not needed for a swap, but there will be a hole requiring a plug if you remove it. I made a nylon plug on my lathe and used the o-ring from the original valve to seal it.
Old May 10, 2014 | 02:09 PM
99z28383's Avatar
Yep, evap crap. Although I'm still running mine...
Old May 10, 2014 | 02:25 PM
TMLoftis's Avatar
Awesome thanks for the fast response guys.
If I just plug it will it have any downsides or anything else that needs done?
Old May 10, 2014 | 02:34 PM
LS1MCSS's Avatar
Turn off the check engine light that will come on.
Old May 10, 2014 | 05:43 PM
TMLoftis's Avatar
Cool. One more hose out of my engine bay
