LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Recommendations on heads/head work that'll work best for my cammed ls1. (https://ls1tech.com/forums/generation-iii-external-engine/1754321-recommendations-heads-head-work-thatll-work-best-my-cammed-ls1.html)
Squidwardo Oct 25, 2014 02:35 PM
Starting to save up for some heads/head work for my '02 z28. Car is a cammed/bolt-on weekend warrior on a stock 10 bolt with 4.10 gears, that'll see very little track time. Just want something that'll shut anyone up that pulls next to me, without compromising reliability. Cheap and reliable are the key words! Anyone have any suggestions? Cam specs are 240/244 .605/.596 112 LSA
ULTIMATEORANGESS Oct 25, 2014 02:53 PM
how much are you looking to spend?
Squidwardo Oct 25, 2014 03:39 PM
Don't have a set amount honestly. Maybe $1500 or so for everything. Parts and labor.
Jtm2085 Oct 25, 2014 03:54 PM
Not really any options for $1500 if your including labor....
HCI2000SS Oct 25, 2014 03:57 PM
Cheap and reliable probably shouldn't be used in the same sentence lol ;)
For $1500 You could get some PRC 5.3 or LS6 heads. Either one are a great bang for the buck
GiggleJuiced_SS Oct 25, 2014 06:04 PM
For 1500 with labor u will have to find a used set and find some one to do the labor cheap. Most cnc heads run 1500 or more by itself. But a stock casting with cnc work is about your only budget option.
Squidwardo Oct 25, 2014 10:53 PM
I'm willing to spend a little more if need be. Just want the best bang for the buck without going overboard. I still have some time to save up and make the final decision however.
GiggleJuiced_SS Oct 26, 2014 01:40 AM
Bang for the buck is oem casting that are cnc'd. Like from Texas Speed. Then u can look at the prc heads also.
MaroonMonsterLS1 Oct 26, 2014 02:33 AM
Advanced inductions has full CNC for 243 casting. You send a core.
If you can assemble the heads yourself it's like $1000 for them "bare"
Like $300 more for .660 lift springs assembled
Plus you can choose combustion chamber size to get the compression ratio you want.
So $1300 plus shipping I think that falls into budget.
Jtm2085 Oct 26, 2014 04:58 AM
For some reason I am thinking the OP was referring to the installation of the heads as well when he said "labor".
mgood613 Oct 26, 2014 07:45 AM
I like the texas speed PRC heads, plus they mill them for free.
kinglt-1 Oct 26, 2014 10:27 AM
Look around and you will find some good deals from members changing directions with their projects. I just purchased a fresh set of 61cc TEA Stage 1 LS6 243's assembled with PAC dual springs and Ti retainers for "close" to your budget.
kinglt-1 Oct 26, 2014 10:40 AM
A fully assembled set of AI 243's is more then 1300.00. Look closely at the website.
1000.00 for the labor and CNC work + 125.00 for new guides, +525.00 for springs, retainers, locks, locators, seals, +50.00 for shipping.
= 1700.00
If you choose to buy the springs, retainers, locks, locators, and seals separate and install them yourself, you would actually have 1875.00 into the heads being AI provides a 175.00 discount for those parts if purchased and installed by them.
Also this price is based on already having a set of 243's. If you still need to purchase a stock set to have worked then figure another 450-500.00 for LS2 and up to 6-700.00 for a set of LS6 with lightweight sodium filled valves.
So basically your looking at 2200-2400.00 start to finsh for a complete assembled set of cnc AI 243's.
Squidwardo Oct 26, 2014 12:36 PM
Alright, guys. Thank you very much for the responses, and sorry for the n00b questions. Guess I'm going to have to cut back on a lot of more things! Haha. Any approximation on how many horses they'll adding?
kinglt-1 Oct 26, 2014 01:10 PM
A good set of CNC 243's can yield any where from +35-50whp depending on the compression increase.
camarodude87 Oct 26, 2014 02:51 PM
Advanced inductions look them up
analyte Oct 26, 2014 10:40 PM
= 1700.00
Just a comment on your total price posted above.
I just got back my LS6 heads with the 232cc CNC porting and I used the BTR spring kit. My guides were in great shape so my OTD price was 1295+55 shipping for the heads. A great deal and Phil is wonderful to work with.
Kerry
© 2026 MH Sub I, LLC dba Internet Brands
