LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Just finished swap... engine won't rev (https://ls1tech.com/forums/generation-iii-external-engine/1754600-just-finished-swap-engine-wont-rev.html)
The stunningman Oct 27, 2014 02:03 PM
I am just finishing a 5.3 vortec into a 1982 C10 truck swap. I used a chevy thunder wiring harness and tune. It is supposed to be in manual mode due to the trans in the truck is a TH375.
It cranks right up and idles like a champ but won't rev past 1500 RPM's.
I reset the PCM and I ran it (as instructed in his DVD material) 5 minutes cut it off wait 30 seconds fired it up. I have done this multiple times... it will not rev. It's like the MAF is disconnected. It is showing 48+ psi fuel pressure at idle and when I try to rev it, it goes up to 60. All connectors are plugged in. I pulled the MAF off my daily and installed it....same thing...won't rev. No codes at all.
I have no idea if abuse mode is in this PCM and have no way of finding out as all I have is a scanner currently. Any ideas as to a way to bypass the abuse mode if that's the problem. I am located in central Va. and do not know LS tuners. Thanks for any help.
gagliano7 Oct 28, 2014 10:15 AM
What year 5.3 do you have? Unplug Maf and see if it will rev then.
The stunningman Oct 28, 2014 08:04 PM
2002. Unplugged maf ... nothing changed but the sec light came on. Still won't rev past 1500 rpm's.
gagliano7 Oct 29, 2014 09:41 AM
Is that throttle cable or dbw? You will probably need someone with tuning software to take a look. When you push down the throttle does the throttle blade open all the way?
The stunningman Oct 30, 2014 09:08 AM
Yeah, it turned out supposedly there are two abuse modes one was turned off and the other was left on. Got it fixed yesterday. All good. Thanks.
© 2026 MH Sub I, LLC dba Internet Brands
