Oil Catch Can Build Questions / Smoking on Decel 17 Attachment(s) I have been having a major issue with smoking on decel after boost. After doing some research it seems like the likely candiate is either VSS Or PCV setup / needing catch cans. After overloading on research for the best setup and catch cans to buy I decided the catch can I wanted was outside of my budget considering I wanted to do a dual setup. I decided to machine my own and would like some honest opinions or ideas for improvement before installation. First, Here is a picture of my engine bay for anyone questioning the setup. Attachment 724314 Here is the PCV Setup I was planning on running. http://www.andersonperformance.net/pcv-2ls1extfi.jpg I started out the basic design with a 3" diameter can, 7" in length. Threaded ends for easy disassembly. I am using a copper tube to direct the incoming air to the bottom of the can, with multiple holes drilled for changing oil level. There is a stainless steel fine wire mesh filter that filters to 60 micron wrapped around the copper tube about 10 times. There is then a diffuser located 4" above the bottom of the can to prevent oil splash. Lastly is a stainless steel muffler with a 50 micron filter. In one of the two cans is a one way valve, while the other Does not have a valve (Between intake filter and valve cover). Bottom has a slight taper to help drain, with a stop cock on the bottom of the can. Thanks in advance for any comments or advice Attachment 724315 Attachment 724316 Attachment 724317 Attachment 724318 Attachment 724319 Attachment 724320 Attachment 724321 Attachment 724322 Attachment 724323 Attachment 724324 Attachment 724325 Attachment 724326 Attachment 724327 Attachment 724328 Attachment 724329 Attachment 724330 |
Looks like a nice design and nice machine work. I dig when people build their own stuff One suggestion I have is maybe adding a safety blow off valve to relieve potential pressure buildup, or possibly increase the diameter of the holes in your diffuser plate to allow for greater exit flow. With boost I'd be concerned that the can in it's current configuration wouldn't flow enough. Is it possible to run a flow simulation on it in its current state to see what the limits are? |
Originally Posted by ckpitt55
(Post 18514939)
If you are willing to go through all this for a catch can, I'm starting to wonder if I should not buy the $30 one on Flebay. :confused: |
You certainly went through a ton of work to make that! My peanut butter jar is working just fine on my high mileage truck: https://cimg8.ibsrv.net/gimg/ls1tech...ef54c4eddc.jpg https://cimg0.ibsrv.net/gimg/ls1tech...855039edb5.jpg |
Today was "dump day". About 2,000 miles of driving. https://cimg1.ibsrv.net/gimg/ls1tech...fd63052612.jpg |
Yes, I did go through a little extra work to make mine. I would not have done it if i didn't have access to the machinery to make it, and would have ended up with something simliar to yours. The majority of the ebay ones are nothing more than an empty can with an inlet and an outlet and won't do much of anything. Mine is just a fancy way to add a diffuser (to keep oil from reaching the outlet easily in heavy turning) and an extra filter with known micrometer filtering. I also added the one way valve for my turbo setup on one of the catch cans. I installed these catch cans yesterday and all smoking issues have vanished, so at this point I don't care if I went a little overboard! |
© 2024 MH Sub I, LLC dba Internet Brands
