Lq4/T5 swap
-early Chevy big block aluminum bellhousing casting # 3899621
-Ls flywheel and clutch
- LS7 Pilot bearing GM part #12557583
what else am i missing?
What are you doing for the throw out bearing? Use a 96-02 Fbody T5 front bearing retainer for a LS1 T56 style HTOB. Quartermaster sells a universal version but longevity is questionable. Fork style TOBs have clearance issues with common 3rd gen LTs and the 621 will position it pretty high, so it may not clear the trans tunnel
I used the late model bearing retainer to use the T56 style HTOB for space
