Exhaust ? Catalytic Converter or No
As it says ? Do I need to run the Catalyic converter on not?
A little info, the engine is 2002 LQ9 DBW w/ Hooker cast iron manifolds. The vehicle is 1991 Toyata LandCruiser. The exhaust configuration would be a Y pipe to single pipe.
I no longer need to pass visual or smog test, as it's too old!
What's the recommended sizes?
I was thinking 2.5 Y to 3 back?
Moderator
Received 1,835 Likes
I run cats, because they serve as a resonator to prevent that raspy exhaust sound a straight Y pipe can cause
