LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   LT's and starter question... (https://ls1tech.com/forums/generation-iii-external-engine/180084-lts-starter-question.html)
99CamaroSS Jun 8, 2004 07:32 AM
I was talking to a guy that owns an F-body at a carshow i was at the other nite...he didnt really seem like he knew too much mechanics wise....b/c his car was completely decked out w/ subs and stereo systems and dvd players and a bunch of other worthless crap when it comes to listening to the engine roar and speeding down the road. But anyways, i was talkin to him about LT's and he said to go w/ shorties or midlenghts b/c he said if i do LT's the heat can effect the starter or something like that. Anyone have any problems after long periods of time? Thanks
jrp Jun 8, 2004 07:41 AM
LT's here and no starter isssues :)
hourang Jun 8, 2004 08:36 AM
if anything LT's would be less heat than shorties.
1BADFNZ Jun 8, 2004 11:41 AM
Well obviously since he spent all his $$$ on stereo and shit you should listen to him about that kinda stuff..... as far as go fast stuff... he probably doesn't have a clue. A bloody starter in simply a high torque electric motor that doesn't operate when the car is running anyways. I call :bs:
99CamaroSS Jun 8, 2004 12:36 PM
Thats what i thought would be all my responses...thanks guys.
1BADFNZ Jun 8, 2004 12:38 PM
Glad to help :)
02WS6Power Jun 8, 2004 12:46 PM
I would think the LT's could possibly shorten the life of the starter due to the fact that it gets the hot pipes closer to the starter. Guess it would depend on which header you get and if you do something to insulate it from the starter.
slik98z Jun 8, 2004 01:17 PM
you can insulate the starter. 99 + mustangs have had this issue (atleast two of the ones i've worked on with friends). chances are it won't happen but as a precaution you can wrap the starter in something, be it header wrap or seal n peal or something like that, it will help out some.
didyou tell him he shouldn't have wasted his cash on the shorties and he could have got some neons to go with the other stuff instead? probablywould have got the same amount of HP out of it.
T
hourang Jun 8, 2004 01:24 PM
i installed shorties in my lt1 and since the collector was right where the starter was and they were not ceremic coated, my started would over heat. you can buy a start heat shield that wraps around the starter, but i seriously think the long tubes will be better on the starter since the collector is like on the ground and not near the starter and if you get ceramic coated ones you should be fine.
davered00ss Jun 8, 2004 05:52 PM
That was a major problem with older cars. They have larger starters than the newer cars like the LS1. Quality headers have more space between them and the starter than older SBC's did.
© 2026 MH Sub I, LLC dba Internet Brands
