Ls1 turning off/low rpms no codes
-radio comes on and off
-My ASR off light comes on by itself
-My RPMS go way down when my ac is on & shuts off
-problem happens even when ac is off
The IAC has been replaced as well as crank sensor and computer. Throttle body was cleaned. Any leads on anyone that has experienced something like this? Or what it could be. Kind of getting tired of it and sucks that i get no error codes or nothing to help me pinpoint this. Thanks
hot weather, fans not running the alternator voltage sag
would canse poor idling and near-death. Believe this was
the alt regulator pulling back on field current when over-
heated. When I started running full time low speed fans
the problem quit happening. Be sure you get good air flow
through the condenser / radiator stack, which gets filled
up with debris over time. Try an experiment where you park
idle with A/C until it starts showing signs, then just open
the hood. If it gets better, look to engine bay temperatures.
Raising idle speed a hair, also can help because now the
alt gets its input power from shaft, not field current so much.
But cleaning and tightening each and every ground and
BAT / IGN junction can't hurt. Don't neglect the terminals
at the battery, copper corrosion is common from leaking
side post terminals (2 Delcos in a row chewd mine right
up, no problems since going to Autozone Gold, cleaning
and soldering over the crimp connections there (you need
a mondo iron for that, though).
