The truth about TB spacers
Old Mar 17, 2016 | 11:29 AM
themealonwheels's Avatar
Originally Posted by thunderstruck507
but what if you stacked your port matched one to a helix one?
What if he added several spacers end to end, effectively eliminating the bellows to the lid? Do the HP gains add or multiply? Is it 5HP+5HP+5HP+... or 5HP*5HP*5HP*...?
Old Mar 17, 2016 | 01:43 PM
GTkllr's Avatar
Don't forget to add a Bully dog tuner and stack it with superchip as well so you get the extra gains with all that new found air coming in
Old Mar 17, 2016 | 01:59 PM
big hammer's Avatar
Thanks everyone. I finally fired it up and let it idle. What a difference! Idles WAY higher. Should hopefully raise my shift point by the same amount
Old Mar 17, 2016 | 06:04 PM
scotty2000ss's Avatar
Don't forget to re adjust the throttle cable
Old Mar 17, 2016 | 06:07 PM
NineZeroFive's Avatar
Not sure if this is satire or not. Either way I'm laughing my *** off...
Old Mar 18, 2016 | 12:15 AM
Darth_V8r's Avatar
Moderator
the problem with those helical spacers is they are with metric thread pitch which doesnt work on US cars. you probably noticed it right away when you were using that standard crescent on it.
that's where I got messed up. I didn't think you could use a left handed crescent wrench to tighten bolts. Only loosen them right? Are you sure it's on all the way?
Old Mar 18, 2016 | 12:17 AM
Darth_V8r's Avatar
Moderator
No, it's exponential. 5^5^5.
Old Mar 18, 2016 | 01:16 AM
big hammer's Avatar
Took it for a quick drive today... Insane! Could barely hold it back with the brakes! Didn't even get a chance to hit the throttle it just wanted to go. I can only imagine when I actually open it up. According to math it should rev to 9000+ at WOT!
Old Mar 18, 2016 | 01:25 AM
CamaroWhoopAss's Avatar
Your thumbnail haunts my dreams...
Old Mar 18, 2016 | 02:33 AM
joecar's Avatar
Did you use a flat washer...? If so, which is the best flat washer to use...?
Old Mar 18, 2016 | 06:42 AM
Good point, not using a washer or an improperly calibrated washer could result in possible blinker fluid boiling, which may allow spark past the spark plugs. Always use the best washers available.
Old Mar 18, 2016 | 07:48 AM
  #32
HioSSilver's Avatar
You wouldn't be the first man to wake up screamin big hammer.
Old Mar 18, 2016 | 09:20 AM
  #33
Darth_V8r's Avatar
Moderator
how much did you preload it?
Old Mar 18, 2016 | 09:38 AM
  #34
98CayenneT/A's Avatar
You absolutely can use a left handed crescent wrench, it just has to be metric.
Old Mar 18, 2016 | 04:43 PM
  #35
slogo's Avatar
1 3/4 turn before it starts moving. Is my guess.
Old Mar 18, 2016 | 05:38 PM
  #36
joecar's Avatar
Using plastigage, I set preload to 0.0015".
Old Mar 18, 2016 | 06:59 PM
  #37
usnfenix's Avatar
I assume your running a thinner gasket in between that spacer to raise compression ratio
Old Mar 18, 2016 | 07:41 PM
  #38
joecar's Avatar
No, I'm using Permatex.
Old Mar 18, 2016 | 08:12 PM
  #39
madmike9396's Avatar
Cresent wrench around here is called a Mexican socket set.
Awesome write up can't wait to try it on mine
Old Mar 18, 2016 | 10:34 PM
  #40
big hammer's Avatar
I would say one of the biggest things is to make sure that the spacer is placed BETWEEN the tb and intake
