Any quick way of knowING size of older fast intake?
I was gonna order a nitrous plate kit and my car had a fast intake on it but I'm not sure what size it came with. Is there a quick way to tell without measuring it? I'm pretty sure it's a older 78mm grey fast but want to be possitive.
Thanks
Thanks
You should be able to pull the bellows and measure the diameter of the throttle body blade, or pull the throttle body and measure the diameter of the intake manifold opening.
25.4mm per inch:
78mm - 3.07" diameter.
90mm - 3.54" diameter.
92mm - 3.62" diameter.
102mm - 4.02" diameter.
25.4mm per inch:
