How can I tell what thermostat I have?
Wanting to dial in my fan settings a bit until I do my cooling system upgrade. No clue what thermostat I have but the car will run between 194 and 205 while driving. Mostly sticks around 194-198 at idle. I assume that's probably a stock thermostat?
Radiators are under optimum size on 98-02 F-bodies. I've had my cars show 200+ scanner temps with a 160 t-stat on 90 degree + days with A/C on at 70 mph. The only real way to know what the t-stat is is to pull it and look down the center hole. The temp will be stamped in degrees C.
Moderator
If it sits about 195 at highway cruise then it's either
a stock ("180"ish) or a waste-of-money aftermarket
"180".
There is no value in changing it out. Get the cooling
airflow (clean, fans, no obstructions) and fin depth
(LT1 core) right and fuggedaboudit.
"180".
