LS1 Exhaust Manifold Hardware kit for 67 Camaro conversion
I got an LS1 aluminum block and head motor out of an F body car. I want to use exhaust manifolds. Putting this motor into a 67 Camaro. I would like to know if there is a correct hardware kit for exhaust manifolds. I spoke with ARP and they told me to use studs not the bolts. I am trying to find studs to use the measurement of the thread is 8 mm x 1.25. 40 mm long. Some studs come with the shank which is no good for me. It lands me right at the exhaust manifold point. Anybody have any ideas??
Thank you. I had previously bought another set of bolts and I had threaded the shank part. I see the part number you gave me also has a much smaller shank in it and I feel it will work. Is it important it stops on the shank?
