Speed Engineering True Dual Exhaust Kits!! - Page 30 - LS1TECH - Camaro and Firebird Forum Discussion
Thread Tools Search this Thread
Old 06-19-2017, 12:09 AM   #581
Default Final Evaluation of SE
So after complete install here is my final evaluation.
Install: I installed the entire system by myself in my garage with no lift. I had help getting in the passenger side header but did the rest solo. I would rate it an B+ (instal guidelines would have been great)
Sound: Top notch sound. I think it's very aggressive and smooth sounding with no rasp. I don't think it's obnoxious by any means. A-
Fitment: The kit went together well and seems really high quality. The bolts were immediately replaced. Clearance is very low. I could not get the clamps tight enough with a high psi impact gun. It kept sagging after driving. I took it to an exhaust shop to tac the welds. That worked well but it's still pretty dang low. It also rubs on my aftermarket panhard bar and has nowhere else to. Some muffler tape seems to have fixed the rattle. Below are my pics after tac welds. It CAN not go any higher on my car. It's stock suspension (may be do for some shocks). I like it, and would buy it again, I won't be lowering my car now and don't reccomend it for lowered cars. B-
Left tip
Right tip
Where it's rubbing
Still on jack
Still on jack
On the ground
Low point
firefighter34 is offline   Reply With Quote
Old 06-19-2017, 08:16 AM   #582
AnotherWs6's Avatar
Curious about the sound too. More concerned about steady state cruising and idling. I'm not looking to attract tons of attention when I'm not trying to attract tons of attention.
AnotherWs6 is offline   Reply With Quote
Old 06-19-2017, 09:29 AM   #583
The sound seems pretty good, it's fairly quiet at idle and people won't know you're packing heat til you give it gas. When you are at low load/low rpm it honestly doesn't sound that loud. It gives a faint air of power, but nothing crazy, and stomping on it gives an incredible exhaust note that almost sounds like a cross between exotic and muscle.
Keep in mind, this is on an LT1 with a factory(or VERY small) cam, so YMMV
PyroguyFTW is offline   Reply With Quote
Old 06-19-2017, 10:05 AM   #584
What brand panhard bar relocation kit did you use?
OLDWS6 is offline   Reply With Quote
Old 06-19-2017, 10:07 AM   #585
If someone can tell me how to upload a sound clip, I can post a few. I agree with ^^^, it's fairly mild at idle. I think my LT's with with flowamaster no cat on my LT1 was equally as loud at low rpm. Again, stock cam.
Old 06-19-2017, 10:08 AM   #586
Quote:
Speed engineering
Old 06-19-2017, 11:13 AM   #587
Cstone812's Avatar
Anyone buy the dumped rear axle kit have any pics or sound clips?
Cstone812 is offline   Reply With Quote
Old 06-19-2017, 12:51 PM   #588
Sponsor
Speed Engineering's Avatar
firefighter34: Thank you for the review. I dont see our new exhaust hanger installed. Might give that a shot for better clearance in the midsection.
Thanks
Sean
Speed Engineering is offline   Reply With Quote
Old 06-19-2017, 05:16 PM   #589
Just installed mine, with 1 3/4" longtubes (bolt on car 2000 ws6). I agree with a post earlier in this thread that it sounds like a diesel. Has anyone had the mufflers cut out and replaced with different ones yet?
96firebirdowner is offline   Reply With Quote
Old 06-20-2017, 07:59 PM   #590
Does or can anyone with kooks true duals duplicate this photo with kooks true duals? Stock ride height preferred to keep clearance same. I'm trying to see if the kooks pipes are angled down like the SE ones.
Quote:
Originally Posted by firefighter34 View Post
Low point
NovaNut21 is offline   Reply With Quote
Old 06-20-2017, 10:02 PM   #591
mac62989's Avatar
^what part of the car is that?
mac62989 is offline   Reply With Quote
Old 06-20-2017, 10:24 PM   #592
Quote:
It is the section after x pipe before it goes up and over the rearend.
Old 06-20-2017, 10:32 PM   #593
that is right under the seats. The red thing is the front of the right traction bar. Maybe the new brace might help but it seems like the exhaust is almost touching the floor boards just behind this picture.
Old 06-20-2017, 11:44 PM   #594
mac62989's Avatar
I can duplicate but realized you asked for stock ride height, mines lowered on BMRs
Old 06-21-2017, 11:14 AM   #595
big hammer's Avatar
Spent more time adjusting my pipes and brackets to get the tailpipes straighter. More satisfied with this kit all the time. I can fit an upright bepis can under the exhaust at the lowest point.
I'm stock height on 28's
big hammer is offline   Reply With Quote
Old 06-21-2017, 11:27 AM   #596
Super Hulk Smash
JakeFusion's Avatar
Kooks has more ground clearance than that with BMR lowering springs.
Also, if you have a cam... or a high stall. Forget about it being quiet.
I idle at 110db with the Kooks TDs. And cruising with it unlocked is 120db.
It's 95db inside the car unlocked and around 85 locked.
If you have cats and a pretty stock engine, the bullets are fine. Otherwise, cut them off and do something like the 6" round Borla XR1s, Magnaflows, or Dynomax Ultraflos.
JakeFusion is online now   Reply With Quote
Old 06-21-2017, 01:52 PM   #597
TheeCamaroKid's Avatar
lowered with BMR coils and i have way better fitment then whats posted above, 2 3/4" above the X pipe, only rubs when i go into my garage
TheeCamaroKid is offline   Reply With Quote
Old 06-21-2017, 01:58 PM   #598
Old 06-21-2017, 05:59 PM   #599
Could you still post up a picture, I'd like to atleast see the if the angle of the pipes are similar.
Old 06-21-2017, 06:01 PM   #600
Quote:
Are you using the new support bracket they made?
Related Topics
Thread Thread Starter Forum Replies Last Post
Speed Engineering Race Version Headers Now Available!! Speed Engineering Generation III External Engine 1316 10-24-2017 11:19 AM
anyone tried the new texas speed over the axle true duals? nnag Generation III External Engine 60 09-28-2017 07:20 PM
true duals damaged Spectre86 Parts Classifieds 6 07-28-2017 12:37 PM
Exhaust goodies! LT1 headers and Full exhaust PyroguyFTW Parts Classifieds 27 06-24-2017 07:53 PM
1998-02 Trans Am Speedometer Bezel DoggyB22 Appearance & Detailing 15 03-14-2017 04:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
