Speed Engineering True Dual Exhaust Kits!!
Old 01-30-2017, 11:50 AM
  #101
2QuikTA's Avatar
Doesn't the kit cone with stainless band clamps? I thought that's what the description said.
Old 01-30-2017, 12:02 PM
  #102
MChampion's Avatar
I'm replacing the supplied clamps with this style: https://www.summitracing.com/parts/SUM-692300-1
I couldn't get even a thin-walled socket over the bolt head or nut on the supplied clamps. When using two open end wrenches, they would just strip out before coming close to clamping the tube.
Old 01-30-2017, 07:03 PM
  #103
codyvette's Avatar
The wide style are what I replace even kooks and AR clamps with. They are much better all around.
Old 01-30-2017, 07:18 PM
  #104
soloman369's Avatar
I bought the rear exit kit and have had a few issues, which is almost to be expected when it comes from China.
My package did not contain the passenger side exhaust tip, packing list of materials, or clamps that are worth your time. Speed Engineering will, hopefully, replace the missing tip and I am buying 9 stainless band clamps to replace the junk pieces in the kit.
As mentioned earlier in the thread, you will need to grind down the washer for the rear-most hangar brackets to fit.
On the bright side, it sounded pretty good for the 50ft I drove it out the door of the shop.
Crazy to hear man . Everything for me went on great and the bands that were supplied were good I was able to use just a regular socket and a wrench to hold the top to tighten them All down. I do hope speed engineering supply the new nuts for future ppl for the exhaust hangers.
Old 01-31-2017, 06:41 PM
  #105
73CamaroLT's Avatar
Whats this about removing the trans cross member?? Is that true? Im getting a 9inch with a tunnel mount TA
Old 01-31-2017, 06:58 PM
  #106
Launch's Avatar
On the problem joins that need a better clamp force, buy 3" Walker U-bolt clamps from summit. They are heavy duty and will clamp the pipes much easier, and proper. $3 each...
Old 01-31-2017, 09:57 PM
  #107
soloman369's Avatar
I had to remove the crossmember to slide the x-pipe in through the tunnel mount. But I put it back on after I slid in the x pipe.
Old 02-01-2017, 04:22 AM
  #108
2QuikTA's Avatar
U-bolt clamps look like **** and crush the pipes. Spend the extra money and get some different stainless band clamps if anybody doesn't like the kit ones.
Old 02-01-2017, 12:38 PM
  #109
Full-Force's Avatar
those wide ones are ****...thin and flimsy as hell.
The thicker ones about one inch wide are the bests clamps but need the slits in the pipes so the clamp can conform the outer pipe to the inner pipe
Old 02-01-2017, 12:43 PM
  #110
Full-Force's Avatar
After looking at the pipes again they all have the slits in them so not sure why anyone would not use the clamps that came with the kit because they are the best clamps you can get unless they are not the clamps I think they are???
Is this what the kit comes with? These are the best clamps on the market
Old 02-01-2017, 12:48 PM
  #111
soloman369's Avatar
Yes very similar to those
Old 02-01-2017, 02:03 PM
  #112
2QuikTA's Avatar
Years ago I bought some band clamps from jegs with a sticky material on the inside to help seal any leaks. I've had great luck with them.
Old 02-01-2017, 02:32 PM
  #113
MChampion's Avatar
I would have used the clamps if they were workable. I could not fit even a thin walled socket on them and when using wrenches, the threads would strip out.
The wide-set stainless clamps are fantastic and I have used them with great success. We'll see how the install goes this weekend with all the parts and decent clamps.
Old 02-01-2017, 03:47 PM
  #114
2ToeRacing's Avatar
I'm having a hard time getting the back half to act right. I just cant get the pipes to point out of the back correctly. Does anyone have pictures from under the car,it sure would help.
Old 02-01-2017, 04:49 PM
  #115
Full-Force's Avatar
To cut cost they may have used a knock-off of the accuseal clamps. You can hit the accuseal clamps with an impact and they will take it without stripping. You can crank the **** out of them.
Old 02-01-2017, 05:03 PM
  #116
Full-Force's Avatar
I believe I would put some turndown on them bitches over the axle!
Old 02-01-2017, 09:01 PM
  #117
zachm89's Avatar
Agreed. If the supplied clamps aren't working for you, spend your money on the acuseal brand of the same style clamps. The thin walled wide band clamps have leaked every single time I have tried to use them. Acuseal clamps on the other hand have never leaked. If you really want to get fancy, weld on some v-band flanges.
Old 02-01-2017, 09:19 PM
  #118
codyvette's Avatar
I have found them to work excellent. You do need to support the exhaust with good mounts. I don't like the fact that the narrower, thicker ones pinch the inner pipe. It can make disassembly a pain in the ***.
Old 02-02-2017, 01:18 AM
  #119
bigfatls6's Avatar
Has anyone tried one of these with a Midwest Chassis double drop tunnel mount TQ arm setup?
http://midwestchassis.com/products/9...unt-torque-arm
Old 02-02-2017, 02:43 AM
  #120
Steven Durham's Avatar
can these fit a 97 Z?
Quick Reply: Speed Engineering True Dual Exhaust Kits!!
