True duals without x or h
BUT I say this because I could let off the throttle and the gasses in the exhaust would build up much higher and would make a very large pop (sometimes quite a few pops) every single time I would blip the throttle. It no longer does it with an H pipe unless I let off from high RPM and let it coast then blip.
I had a combo that ran quiet with full exhaust and only popped on decel with the cutout open...does that mean that my cutout added back pressure?
Back on point regarding X vs H vs Y vs dedicated pipes.... It's mostly about sound and what fits.
Shelby Cobra with the 427 motor had dedicated side pipes.
Vipers have come with dedicated side pipes, dedicated long pipes to tail, and dedicated pipes that only join inside the center exit chamber muffler.
Corvettes have come with H pipes, X pipes, and dedicated side pipes.
Fbody with same motor and Y pipe make the same power as the corvette.
Don't C6Z and C6ZR1 put an X pipe after cats? Cats hinder flow way more than mufflers.
1)i think i can do the same clearance if not a little more cleanse with a single 4
2)to pass pa safety inspection exhaust must go all the way out back or side exit away from vehicle in front of rear tires......mid 2000s viper style....obviously we don't do this to fbodys. any i want dumps.....so it will be easier to make a temp side exit pipe that is removable for inspection time.
3)wanna try something different. also kinda looking for as loud as possible without a cutout cause again, some shops will fail you for a cutout. technically pa law says no cutouts allowed. and figured 1 dynamax bullet will be louder than 2 dynamic bullets.
