Ls6 valley & catch can, still huffing oil into the intake!
Can someone point a brother in the next direction?
Just installed a fast intake and saw oily head runners, again.
This is only after about 1500miles after updating to a new ls6 valley cover, newer valve covers with the drivers side plugged and pass side only with the TB vent. Plus a norris catch can that gets a few milliliters every 1k miles I am still getting lots of oil pulled through the intake under wot.
Seems everyone else is not having this issue after all the work done like i have.
Also only gets M1 0w-40.
Been doing some research about running a metco/cfm oil cap breather but getting mixed results, either got to delete all the pcv system and run breathers or stay closed pcv system. Can i just add a breather with a check valve that will allow an exit during high pressure?
I do track the car so it sees high rpms and wot for long durations, id really like to stop the oil consumption! Sucks having a fast car that smokes like a diesel
Here are pics of the current setup:
If you want to keep the PCV system then the fix for you will either be run an additional catch can for the clean line (line from valve cover to throttle body) or put a one-way check valve on the clean line (allowing air from the throttle body to the valve cover but not back out) and then run a breather with a one way check valve out so any pressure build up that would normally push up through the clean line would now be vented out, but not allow air back in.
Here are pics of the current setup:[/QUOTE]
I agree.
My 99TA at WOT was beyond smoking and more like a death fog generator for any mosquito in the same zip code. 99 percent of the problem was bad valve seals. The car guzzled about one quart of oil every 1,200 to 1,500 miles and much faster with any high rpm.
After valve stem seals oil consumption dropped to about half a quart every after 4,000 miles. At WOT there is a very slight trace of smoke at 6,000+ rpm. It's amazing how much new valve stem seals did toward reducing and almost eliminating my cars smoke issue.
You DO have quite the way with words.... Couldn't have come up with a more illustrative description myself! Got some chuckles outta me, for sure!
Very annoying problem. I have 99 engine with no valleycover breather. I have tried couple of catchcan setups made by myself but nothing really helps from 100% oilproof. Now i breath after catchcan staight to athmosphere. Problem solved I think the real problem is in diameter of ventilation tubes. Small diameter flows too fast and the "atomized" oil flows with it. I have done many european four bangers engines without this problem. They have breather tube size +1 inch or so and the speed of flow is minimal.
