anyone tried the new texas speed over the axle true duals?
#61
Looking at some of the pics there is still plenty of room to adjust some of those up higher. A quick tip would be to place a jack under the mid pipes with a block of wood between the jack and pipes. Loosen the clamps, push everything up higher, then clamp it all tight. This will improve clearance quite a bit.
Also I will state that our website does have a note for those with lowered suspensions. "If your vehicle is lowered, you may need to modify or adjust the system accordingly. All measurements for our system were based off of a stock LS1 f-body at factory ride height."
#64
