I don't know what pulley I need! I'm in the process of putting together my first build. It is an LQ9. The alternator and bracket I have are from a 5.3. I want to mount my alternator down low, and won't be running any other accessories off other than the alternator. Im looking into ATI. Which part number should I be looking at? This is in a foxbody by the way. Thank you. |
The size of the engine doesn't have anything to do with the offset of the pulleys. Saying your brackets "are from a 5.3" means absolutely nothing. If you don't know what vehicle they came from, you're shooting in the dark. |
Originally Posted by moviehall24
(Post 19759794)
LQ9's and 5.3's all start out as truck engines. So they also all start out with the same accessory/belt setups. Tell us where your stuff came from. |
I just ended up getting an f body pulley since I plan to use an alternator relocation bracket that works with the F body spec pulley |
| All times are GMT -5. The time now is 09:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
