99-02 LS1 FBody 100% "soup to nuts" E85 kit?
#41
That's pretty amazing.
Would the flex fuel set up with the 02 Tahoe sensor and new operating system also work for a 99-04 C5 Corvette?
#42
Originally Posted by 01ssreda4
Do wha
#43
Well thats new to me cause Im running one. 3bar sensor, HPTuners has the setting built in, bada bing bada boom. Done.
I will clarify, its 3bar, SD, with real time tuning. There are different versions of segment swaps for different PCMs, with all different options.
#44
Everything I’ve found so far in order to run flex fuel and a 3 bar map on our cars you have to swap to a p59 pcm.
At one point flex fuel “wasn’t possible” on our cars lol
I know you can run 2 and 3 bar on our cars without flex fuel as I’ve done it as well.
#47
I ran across this "kit" while browsing today, looks as if it just came out...
https://www.advancedfueldynamics.com...-corvette-ls1/
#49
#50
"Vehicle Fitment
Submodel: C5
Engine: 5.7L LS1 V8
Years: 1997-2004"
No mention of it cannot be stock?
My question would be, shouldn't this work on the LS6 as well?......................LS6 kit coming soon
#51
I am assuming that the C5 vette uses the same pump and injectors as the LS1 F-Bodies.
You'll at least need this pump: https://www.texas-speed.com/p-2361-r...-assembly.aspx
And these injectors: https://www.texas-speed.com/p-248-ra...injectors.aspx
#52
This is the fuel pump that I am thinking of using... just need to confirm that it is a direct replacement for a Walbro/racetronix 255: http://www.hawksmotorsports.com/walb...l-pump-465lph/
#53
"Do I need to replace my injectors and/or fuel pump to run E85?
We do R&D on each and every application we sell systems for and most stock vehicles do not need bigger injectors or fuel pumps to run full E85. If your vehicle requires changes to the fuel system, it will be noted on the product page. Also, depending on your vehicle’s setup (specifically if you are running an aftermarket supercharger) you may be limited to how high a blend of ethanol you can safely run. Please contact us and we’ll be happy to talk with you about your specific application and setup."
There is no mention of bigger injectors or fuel pump required to run this kit on a stock C5
Here's the note on the 03-06 W211 Mercedes E55 AMG (M113) kit:
"PLEASE NOTE: The W211 E55 AMG requires upgraded fuel pumps and injectors to safely run full E85. Fuel pumps and injectors are not included with the PROFLEX Commander kit and are sold separately. "
Note for the BMW E60 M5 & E63, E64 M6 (S85) kit:
"Please Note: Cars with a supercharger may require upgrades to the fuel pump and/or injectors to run full E85. Supercharged M5 and M6s should be dynoed or logged to ensure the fuel system is able to meet the demand of the fuel or blend customers wish to use to ensure safe engine operation."
