Worth It To Upgrade To Gen. IV Truck Intake?
I'm currently running the Gen 3 truck intake-early style with EGR provision from a 2000 5.3 truck. I just came across a later truck style intake from a Gen. IV motor and it was a freebie to me.
For a low rpm/torque motor only application, is it worth it to change over from my current intake to the later style intake? The later intake is also a 4 bolt TB intake, and I'm running DBC so I will need some type of adapter, or is there another way to fix this?
Any input would be appreciated.
Restricted User
You will gain some torque at the least. You can run a cheap adapter for your throttle body or spend $90 on ebay ebay 4 bolt throttle body. If you go the big throttle body route, you'll want a tune.
