Trying to find LS1 75mm Throttle Body - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 01-13-2018, 03:29 PM
Default Trying to find LS1 75mm Throttle Body
Looking to replace the 3 bolt 75mm throttle body on my LQ9 with LS1 intake. Can't seem to find one with the connections like the one i have. There is a hose from the water pump that goes through a tube on the bottom of the TB and then to radiator. Do i have to have that or can i bypass it? I have a 75mm port in the manifold so i assume i have to match that. Any suggestions for a vendor to find this?
Thanks,
Keith R
Attached Thumbnails Trying to find LS1 75mm Throttle Body-tb2.jpg   Trying to find LS1 75mm Throttle Body-tb1.jpg   Trying to find LS1 75mm Throttle Body-tb3.jpg
Flynman is offline
Old 01-13-2018, 04:29 PM
ss.slp.ls1's Avatar
I thought the LS1 had a 78mm TB? Either way, the coolant tubes are just to warm the TB for emissions if I am not mistaken. I believe you can bypass it without issue.
ss.slp.ls1 is offline
Old 01-13-2018, 05:12 PM
SS.slp.ls1 I measured the throat and it was 75mm. This motor came out of a Silverado 2500HD but the intake manifold i was told is an LS1 not sure which year or model..Could i go with a 78mm?
Keith R
Flynman is offline
Old 01-13-2018, 07:37 PM
Any 3 bolt will work, and usually considered 78mm. The vacuum port on top is turned different for cars and trucks but I just heat the throttle body at the base of the port and turn them to where I need them.
tug686spd is offline
Old 01-14-2018, 03:00 AM
sjsingle1's Avatar
that looks like a everyday run of the mill LS1 TB.....hell i have 2 sitting around gathering dust
sjsingle1 is offline
Old 01-14-2018, 09:34 AM
01ssreda4's Avatar
They are 75mm. OP, yes bypass that lower hose, you dont need coolant running through there. Just about any 3 bolt tb will work, as stated above.
01ssreda4 is offline
Old 01-14-2018, 04:27 PM
Ok..Thank you for the replies!!! Going to clean this one up and polish it and see how it goes. Having some stalling and surging idle after the car is driven for about 15 minutes....Before that it runs and idles fine. Checked for codes and nothing is coming up. Didn't find any vacuum leaks and MAF and MAP are only a few months old.
keith R
Flynman is offline
Old 01-14-2018, 05:54 PM
01ssreda4's Avatar
There was a minor butterfly difference. I think 01 and 02 fbodies got a longer more progressive butterfly cam (thing the cable pulls on). Its noticeably bigger/longer then earlier years and trucks. That looks like a truck TB. Picture truck ones like yours as that piece looking like a half a pizza, and the odd fbody ones looking more like a crescent moon.
Quick Reply: Trying to find LS1 75mm Throttle Body
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
