LS1 thermostat ?
when TS is closed, the BP opens easily to allow coolant from the block to go thru the pump;
when TS is open, the BP usually stays closed (i.e. is more difficult to open), this forces coolant from the block to go thru the radiator;
see attached coolant flow "schematic" I drew (I measured the spring rate and and surface area, from these I calculated the approximate BP opening pressures; and I traced the passages thru the pump, the circle and square represent the passages at the pump and block interface).
