Ls6 intake+28.8 lb injector on 2000 ws6
Long story short my friend bought a supercharged ls1 GTO and got all of the factory parts. He's giving me the ls6 intake with the fuel rails, 28lb injectors (vs the 26lb ones in my 2000 ws6), and valley cover for a good price. Will I be okay running untuned for a while? I want to get a tune after I get longtubes and don't want to do it twice. I know it will run a little rich with the slightly larger injectors but will it be enough to cause me problems?
Actually your O2 sensors/MAF might adjust for it, but I'm not positive about that.
I asked my tuner this same question a bit ago and his answer is you have to retune anytime you change to a different injector... even going from stock ls1 to ls6.
So so as stated above I'd use your ls1 injectors now and when you get your car tune do the injector swap.
THIS!!!! Ill say it again, the GTP stock injectors drop right in, just need a tune. They flow 42#'s at LS fuel pressure. Make sure you have a decent fuel pump to support the fuel system. Even the 28.8's are a little small once you have a couple mods. I was generally running 110% IDC with those on a bolt on. The GTP injectors are in the high 60's.
The following users liked this post:
wannafbody (04-25-2021)
