Button flywheel won't fit https://cimg1.ibsrv.net/gimg/ls1tech...f7bcbc0feb.jpg I bought this flywheel to fit my ls1 with callies crank and the bolts are slightly out and it wont fit on the crank amy ideas ? |
You mean the bolts don't line up? Return it. |
Originally Posted by G Atsma
(Post 19927161)
The LS 6-bolt flywheel pattern has not changed. I noticed you got it from eBay. There's your reason why it won't fit. Sloppy machining. One thing. You do know that one bolt is supposed to be "off" a bit from the pattern, right? Rotate the part until all holes line up. |
Hi. It's a quartermaster bought from speedway motors from Lincoln it's still tight on crank also not saying a bang with a hammer won't get it on but the bolts are off what ever way we try. I am based in the UK so ebay was the easiest way not the preferred way. |
I haven't had any issues with qtr master buttons not lining up like that. |
https://cimg5.ibsrv.net/gimg/ls1tech...9be708888d.jpg Here is tje new flywheel over laid ober the old you can see the difference. https://cimg4.ibsrv.net/gimg/ls1tech...419893ef18.jpg |
The flywheel says “Quater Master”....or am I seeing things wrong? I believe that’s a typical Flea-Bay imitation part. I’ve ran lots of QuarterMaster stuff in my circle track stuff, and it’s high quality and highly priced stuff. Send it back. You can get a real one from Jegs for $15 cheaper, and it ships directly from QuarterMaster. |
It's a quartermaster part from a trusted seller button fly wheels are not expensive . what is the difference between early chevvy and ls any ideas ? |
Originally Posted by Julianb
(Post 19927291)
It's a quartermaster part from a trusted seller button fly wheels are not expensive . what is the difference between early chevvy and ls any ideas ? Not sure about the bolt patterns being different. |
It DOES indeed say "Quater Master", and no, a company is NOT going to misspell their own name on their product. This one is NOT a Quartermaster. Your "trusted" seller is not to be trusted. Did YOU buy it from Speedway yourself? Or thru a middleman? |
Haha yes I see it I did but it from speedway direct I have contacted them and if there is any trouble I will go through PayPal for a refund as its counterfeit. |
(Post 19927319)
I hope so nut it's put our build back by 3 weeks now we was under pressure to get it finished as it is but now who knows. |
| All times are GMT -5. The time now is 07:49 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
